To fasten it, why not some VHB tape? Or 5200 or Sikaflex? Those would removable (with some effort...) and would not create leaks. Should be plenty strong enough, but does depend on the skin being solid or fastened to something solid. That is how I intend to mount one if I do anything.
JimK-NY wrote:
I would expect Zero improvement. The gap between the truck and camper seems to be a total dead zone. I have never seen bugs, dirt or water enter that area regardless of speed or conditions.
I have little or no significant wind noise due to my camper. If you have wind noise, I would look elsewhere. Start with protrusions and irregular areas. I would look at the gutters, running lights, vents, and similar.
On your camper. Not mine. I have quite a harvest of bugs mainly on the outside edges of the camper but extending in and even all the way across up high (over the cab). There is also a nice pattern of bugs under the overhang somewhat defining the shape of the cab. There is definitely more wind noise with the camper on that with it off. Every situation is going to be different. I have a supercab, not a crew cab truck, so the camper overhang extends some distance ahead of the windshield. The camper overhang sits pretty low, maybe only 6" above the cab roof. The Bigfoot has no sharp corners or irregular protrusions. The airflow around the truck and camper has got to be pretty complex, not easy to visualize without a wind tunnel. I've thought about tufting it and photographing the flow, and might do that prior to and mods.
pianotuna wrote:
Consider Air Tabs?
I've looked as them, and could see the possibility of filling in the low pressure behind the camper. Less sure about the area underneath the overhang. Back when Sleepy was describing his, someone did pop up who had tried the on the front of his camper - put them underneath the overhang if I remember - and said they reduced the wind noise. If they were cheap I might try that, actually it would only cost about $70 so might be worth a try.
