JohnInWI
Oct 21, 2017Explorer
Winnebago Micro Minnie 1706FB - actual bed dimensions?
Very close to buying one, but local dealer doesn’t have a 1706 FB in stock.
Vague winnebago web site claims “queen” for floor plans.
We actually measured a 1700BH and a 2106FBS in stock with a tape and they were very different between them, and neither close to 60x80. 54” wide only for 1700bh - that is a double, NOT a queen. 2106fbs was wider, but a LOT shorter where my feet dangled over the end.
If you own a 1706FB and can measure the bed, what is it in reality?
We also found the 1700BH has a hidden feature where you gently pull a handle and the entire bed flips up on lift struts and a piano hinge providing fantastic access to the entire storage under the bed from inside the trailer!. Every Micro Minnie should have this, but i fear the 1700bh is unique on this feature. May be able to DIY this in a 1706FB, but sad that it isn’t like this from the factory. Or does your bed lift up!?
