joe_julie81ExplorerNov 20, 2020Winterization of hot water heater?After draining all the water from the tc,including removing the plug from the hot water heater, what else? The anode attached to the plug is half eroded away, I guess it should be replaced? Should ...Show More
billtexExplorer IINov 21, 2020Check your water heater tooNot sure why you would need a hot water heater?
Related ContentAtwood water heater problemSmelly Water HeaterWater Heater Replacement RecommendationsWinterizing tankless water heaterWater pump?
