Texan79423 wrote:
I have my TT winterized, tire covers, check battery water level, and parked under a shed. My plan is to leave the battery in the battery box.
I left it plugged in to 110 outlet for three days to charge but did not check it with a meter just assumed it charged.
l flipped the disconnect switch to off. I plan to go out and plug it in once a month. I have a wet Interstate 24 battery.
Hope this works and replies welcome
No problem.
It is great if you want to go out once a month and Flip The Disconnect Switch Back On and then charge it up again. But, as long as it was charged before you shut it off you are good to go even if you don't recharge it very often.
(This is assuming that the disconnect switch actually disconnects everything. It should but, you never know how stuff is built)
