greende
Sep 22, 2015Explorer II
MM49 wrote:
Air Pressure doesn't work. Water will remain trapped in segments of the lines.
you must use antifreeze after the air blow out.
MM49
I respectfully disagree. I have used only air to winterize for the past 20+ years. Even use it to blow out the traps. Never had a freeze problem and it does get rather cold here in Upstate New York.
