jasoncw
Sep 22, 2015Explorer
MM49 wrote:
Air Pressure doesn't work. Water will remain trapped in segments of the lines.
you must use antifreeze after the air blow out.
MM49
I have only owned a TT for 5 winters so far, but all I have ever done is blow out using a compressor. Never had an issue. And you know how cold it dropped a couple years ago... Air pressure does work, and it works well, as long as you ensure you blow out all areas that hold water.
