Bigbird65
Sep 22, 2015Explorer
MM49
I respectfully disagree. I have used only air to winterize for the past 20+ years. Even use it to blow out the traps. Never had a freeze problem and it does get rather cold here in Upstate New York.
After you drain the fresh water tank, do you run the water pump dry before you blow the lines? What is your sequence?
