mdcamping
Oct 26, 2021Explorer
Terry 25 wrote:
for incapacitated brother. Where is drain for fresh water tank? Found low point drains toward front driver's side. Thanks
Hello I have an similar Jayco X20E The fresh water drain should be almost directly below the fresh water tank. Should be a small white plastic valve. Sometimes it's hard to see if there is water in the tank so If your not sure put a small amount of water in fresh water tank and turn knob till water comes out. Not really a flow directional on those cheap valves, so sometimes it good to make comparisons
good luck
Mike
