RoyBell wrote:
I don't even see the freshwater tank drain :?
It's only supposed to get low 30s tonight, maybe dip into high 20s. Figured I better get started on the process.
It is UNDER the TT under the fresh water tank.
Only in the 30s don't worry.
However. Sinnce you have put water back into the lines, and you want to run antifreeze thru the pump. Do that, and go to each faucet. Including the shower, and toilet. Turn them on one at a time until pink comes out. Pour some pink down into the traps. You are done. No need to blow out the lines with antifreeze in them. Leave it there. Also do pour some in the toilet, and let it stand. to keep the seals wet
