OK I found the freshwater drain. It was hidden behind the leaf on the slide side. I had the slide open so I couldn't see it from the back or entry side.
Not much came out, Ran air through the lines again. No water came out of the faucets even. Probably because I had the lower lines open when I turned pump on and it went there first?
Either way, I pumped 2 gallons of AF through the lines.
Opened the faucet valves and lower drain lines and gravity drained the lines.
I would prefer to blow the lines again to prevent the AF from sitting in them all winter transferring the smell and taste. I have read half the people blow again and half the people just leave it.
