mobeewan
Oct 28, 2017Explorer
You might pick up a 5 gallon air tank at Wal-Mart or somewhere. You might use it as the tank for your compressor you already have.
I've got a 5 gallon air tank I bought at Walmart a long time ago that I used to use for topping off tires. It was rated for 125 psi. I have used it in the past for blowing out water lines in my first trailer between hunting trips. Then I would leave the trailer at a friend's place near where I hunted between trips. At the time his well had been running low and I didn't want to use up his water flushing antifreeze when I used the trailer again. It worked fine. I just had to plan out the most efficient way to make sure I blew out the lines well enough.
44,070 PostsLatest Activity: Sep 18, 2026
