Latner
Oct 28, 2017Nomad
GordonThree wrote:TurnThePage wrote:
How do you compressor based winterizing guys clear the water pump?
advocates of the quick blow method don't talk about how long they spend to disassemble and drain the pump and strainer.
Locate the pump and unscrew the intake/output fittings and remove the strainer, takes 60 seconds if that. Run the pump for a few seconds to push out most of the water in the pump and leave it that way until you need to use it again.
44,070 PostsLatest Activity: Sep 18, 2026
