wmoses
Oct 07, 2014Explorer
I am confused at your second post.
You said you had an existing thermostat in a bad place and want to move it to a place that makes more sense, like in an open area in the middle of the trailer. You also said you wanted to avoid rewiring the thermostat (which I assume is presently wired in the aforementioned wrong place) hence your request for info on some wireless solution.
How is putting up a picture if a thermostat that requires wiring going to solve your issue? :h Are you thinking of replacing the existing thermostat with the one pictured in the same wrong location?
If you want to relocate the thermostat, you have to run the wires to the new location and then hook up a thermostat of your choice. The one picture would be fine although if it were me and I were getting a new one anyway, I would get a digital thermostat to more finely control the temperature swings either side of the set point.
44,070 PostsLatest Activity: Sep 18, 2026
