BossCamper
Oct 07, 2014Explorer
wmoses wrote:
I am confused at your second post.
You said you had an existing thermostat in a bad place and want to move it to a place that makes more sense, like in an open area in the middle of the trailer. You also said you wanted to avoid rewiring the thermostat (which I assume is presently wired in the aforementioned wrong place) hence your request for info on some wireless solution.
How is putting up a picture if a thermostat that requires wiring going to solve your issue? :h Are you thinking of replacing the existing thermostat with the one pictured in the same wrong location?
If you want to relocate the thermostat, you have to run the wires to the new location and then hook up a thermostat of your choice. The one picture would be fine although if it were me and I were getting a new one anyway, I would get a digital thermostat to more finely control the temperature swings either side of the set point.
I must have deleted some of my second post. I was indicating that the therm. I have looks like the one in the pic.
Yere are lots of thermostats that do what I want ... leave the wiring and receiver where it is, but have the sensor somewhere else. No wiring needed, BUT there are none that are 12 volt. They're all 24 volt, so I'll just have to bite the bullet and rewire.
44,070 PostsLatest Activity: Sep 18, 2026
