BossCamper's avatar
BossCamper
wireless thermostat extender?
The thermostat location in our trailer was designed by a real rocket scientist!
It`s right behind the top if the TV that is mounted where the TV mount backing support is! To make matters worse, there is an overhead cabinet just above the TV which holds the heat in!
The heat from the TV keeps the AC from shutting off, and the furnace from ever turning on!
In order to avoid rewiring the therm. and leaving a hole where it is now, I'm wondering if anyone knows of a wireless extender of sorts where the therm can be placed somewhere else with the receiver mounted where the old therm. is now.
  • Never mind .... Google is your friend.
    I guess my question should be .... if anyone else has done this, you could give recommendation or reviews for models that will work with an analog therm.
    looks like this
