BillB800si wrote:
When we had our 2007 Jayco Eaqle 322FKS we had an electrical problem the 2nd year. I finally found it in the electrical panel. Seems that after a few thousands miles of travel some of the wires in the panel had loosened up and was arcing. This caused a build up of resistance on the connections. Plus I found some of the wire insulation has melted off the A.C. wiring. I then cleaned up the terminals- reconnected the clean wires and tightened everything down.
That was the fix....
Hope yours is that easy.
Happy trails,
The same thing happened to our 2007 Jayco Eagle 288RLS last month when we were 3 days from home.
We sustained smoked circuit breakers and melted wires also.
After returning home I replaced the Iota fuse panel/converter with a Progressive Dynamics fuse panel/converter with 4 stage battery charge.
The Iota in our our unit did not have the 4 stage.
Bob
