mhardin wrote:
enblethen wrote:
Operating water heater electric element and AC on a fifty amp shore power is no problem. Operating it on a thirty amp can be more then what it can handle with addition 120 volt loads such as converter, and microwave.
Well, if you want to include the microwave, you are correct. I have to turn something off to use it. However, I have no problem with running the water heater, A/C and converter at the same time on 30 Amps.
I have run the water heater, A/C and microwave on 30 amp at the same time at
most campgrounds. It's only when my wife adds the hair dryer to the mix that I pop the breaker :S
