enblethen
Oct 24, 2015Nomad
Yes, a good wire directly to battery should be good, however the lights may have a separate ground connection.
What kind of truck is the camper on?
You could have blown the fuses under the hood depending on make. Some have the trailer connector fuses under the dash.
Is this the wiring diagram you are going by? Make sure the black and white are not reversed.
Wiring diagram
Wiring diagram
