bdlaise
May 28, 2014Explorer
Wobble Stopper
It pays to read the trailer life magazine. In the May 2014 edition I found this tip/modification in the 10 minute tech section submitted by two other RVers. I used the same materials. These things really do reduce the bounce and wobble in the trailer. They're easy to setup and didn't cost that much to make. The materials needed are two 8 ft 2x4s, two 10-to 14 ft cargo straps *get the ratcheting kind instead of the friction type, you'll get better tightness). Cut a 45 degree angle were the 2x4 meets the top side of the frame, then determine the proper length you'll need based on the height of your trailer to the ground. I cut a 30 degree angle on mine, but you can use a 45 or what ever angle best suits your needs. The drill holes through the 2x4s for eye bolts approximately 6 to 8 inches from the end closest to the ground. I opted to split the difference and place the eye bolt in the center or just off center (towards the ground end) to keep the cargo strap out of the dirt, and provide a uniform pressure against the frame and the ground. I stained and sealed mine, for looks and protect them against the weather. Like the others RVers noted these really do make a difference.
