- DutchmenSportExplorer
2012Coleman wrote:
DutchmenSport - I'll give that a try, but am wondering if they will slip back to the wobbly position during use.
Another thing to consider, take the table down when traveling. The rocking of the camper is causing the weight of the table to wiggle, causing the aluminum posts to bend inward. By simply taking the table down, the legs will be spared. We did this with our Springdale from delivery to the day we sold it. The legs were still solid and never wiggled. Our current camper has a stand alone table now. - 2012ColemanExplorer IIDutchmenSport - I'll give that a try, but am wondering if they will slip back to the wobbly position during use.
- DutchmenSportExplorerIf you table sits on 2 aluminum posts that slip into a sleeve on the floor and another sleeve under the table, you can pull the crimped ends of the aluminum posts out just a little (very little), making them fit more snug in the sleeves.
Or, you can attach mount on the side of the wall that will enable the table to dismount. Put a folding leg on the table so you can still use the table as a bed. - 2012ColemanExplorer II
SoundGuy wrote:
Table is located alongside a wall - not U-shaped.2012Coleman wrote:
What have you done to stabilize a wobbly dinette table?
Depends. If the table is located alongside a wall then it's an easy fix, one I did myself in our previous KZ Spree, but if it's a table that's part of a U shaped dinette with no wall next to it then that would require an entirely different approach. Whatchagot? :@ - SoundGuyExplorer
44,050 PostsLatest Activity: Sep 20, 2025
