anutami's avatar
anutami
Explorer III
Sep 28, 2014
Wolf Creek 850 Solar Install
Started phase 1 of my solar set up. Utilized the maggie rack with uni strut cross members thanks to an extreme boondocker one of a kind truck campin' guy :).
Placed two 100 watt panels.
Removed access panel behind the command center to find my solar wires
Wires were right there
I removed the access panel in the upper cabinet as well to get to the cheesy splice and top solar connector Northwood installs
Here is the cheesy solar connector I removed from the roof
I hollowed out the middle and fed my own cable right to my solar controller
Here is my controller. I am supposed to have 6" of clearance on the top. Do you think I will be okay leaving it where it is or should I move it down?
I was going to use a junction box but opted for the mc4 connectors because the panels came prewired with the mc4 connectors already. I will see how this works out. I was tempted to install the panels next to the fantastic fan on the cabover roof part, but didn't want to drill into my roof yet and wanted to keep the weight over my truck bed.
Again thanks to Bryan for the hot tip on unistrut :)
  • anutami wrote:
    What they heck is that thing sticking up with tapr over the top of it?
  • I also hate those stupid splices! Sure wish they'd factory install 10AWG wire instead of 12.
  • Nice set up, Nolan. We are also looking into solar, but may wait still the spring to install. The weather where we are is rain rain rain everyday in the winter. We don't want to risk drilling holes into the roof and then get water leaks.
    What size of wires did you use to replace the OEM 12-awg wires?
    What are mc4 connectors? can they be hooked up directly to the cable you show in the picture?
  • You're going to love having solar!
    These are 100 watt panels also. Here you can see what they look like on the cab over.
    I like your use of strut, almost did the same myself, I did however make my own mounts with aluminum angle.
    I used a junction box to manage all the wiring and abandoned the pre-wire to get larger 6 gauge wire as each is wired parallel to somewhat compensate for the inherent shadowing.
