anutami wrote:
The issue appears to be the 2 ducts that blow hot air and the air intake vent are right next to each other. So my hot air is essentially getting sucked back in the intake and overheating the limit switch causing it to shut down. I had both ducts pointed down drying off wet snow gloves and jackets. I am pointing both ducts upward and will see how that works.
Maybe the limit switch itself is faulty (too sensitive). All AF TCs, and maybe Wolf Creek too, have their furnaces and ducts under one dinette area, with the intake close to the supply ducts. If that was the case there would be many other owners with this same problem.
