CA Traveler wrote:
Grey water is not clean faucet water, it's contaminated water that stinks. And when it leaks dry rot may have started. Dry rot results from wet wood with no air circulation ie this tank design. And when it does leak repair or replace.
But I like the idea as a proof of concept.
"Dry rot may have started." SO WHAT? You unscrew the tank from the bottom of the camper and replace it.
You act like this is an integral part of the camper buried somewhere inside where you wouldn't notice a problem for years. It's an external module that has nowhere to leak, except to the outside. You'd notice right away if it leaks.
I don't want to know what you do with your gray water; mine "stinks" like Old Spice bodywash.
