Jfet
Jul 15, 2013Explorer
8000 threads in here about wood rot with some ghastly pictures. I am not sure I could find 10 threads showing failed aluminum weld joints.
(we used steel in our build so I am really not worried at all about the weld joints....unless we hit a concrete barrier at more than 30mph).
I think the condensation problem (the transfer of heat through the aluminum frame from inner wall to outer wall) could be solved by putting insulation over the frame between the inside wall and the frame members. This is what we did. I am not sure what livin lite does.
