jimh406
Jul 15, 2013Explorer III
gkirtley wrote:
I have heard poor welds with no apparent fusion described as "wormy" but these would be more accurately described as "worm crap" or worse.
You can weld poorly with any process to make it weak, but you can also split wood. If you look at some of the frames of campers, you'll see that as well. Finally, you can poorly build fiberglass campers as well and do a poor job at sealing the holes or warp the shell or lay it too thin.
Finally, campers are built one at time so quality varies. You might want to give all RVs a wide berth.
44,071 PostsLatest Activity: Sep 17, 2026
