- LAdamsExplorerExcellent job!!! Better than new... Nice to see a true craftsman at work :W :B
BTW, I looked at your first post and your using the wrong syntax from Photobucket for posting your pictures... Use the last choice in the list under your pictures that says "IMG code"... Just click on that in photobucket and you will see the word "copied" when you do that... Then just paste that syntax into your post here on RV.net... Below is an example from one of pictures on photobucket...
Note the text that says "width=640"... If you type that into your copied IMG syntax from Photobucket after pasting it into your post here, that will automatically resize your photo to the correct maximum size for RV.Net and it will hold the correct constraints for width/height ratio as well...
Les - CavemanCharlieExplorer IIIDo you want to come do my kitchen? Your better then my local carpenters.
- shasta24Explorer
keepin warm - shasta24Explorer
- westendExplorerVery nice work. I see you have at least one new window, that is a good decision.
- shasta24Explorer
Thanks to everyone who helps on this forum. My trailer is turning out nice. - shasta24Explorer
Frig and micro cabinet - shasta24Explorer
New sitting area - shasta24Explorer
More progress - shasta24Explorer
I hooked up a battery today, to check all the circuts. Im going to have more wire in this than it ever had from the factory. Insulation is next, just going with fiberglass,and you might have noticed Im using tyvec. I know some people say not to but it made sense to go that route.
44,025 PostsLatest Activity: Feb 06, 2025
