yankeeslover wrote:
I found out the charger/converter on my 2011 featherlite is this model. is this a decent charger? im debating wether I want to return my just purchased $40.00 battery charger and save the money and instead use the onboard charger. I would just have to figure out how to tell if the battery is fully charged before I unplug camper. also, I have an interstate hd24. are these ok batteries? will 24 last a weekend of lights/pump? im not sure my battery box can hold a bigger battery, I don't think it can..
I see you had a topic 4/30 on this as well. new battery charger...please help!!!!
I have that 8735. It is an adequate 13.6V power supply and has a so-so battery charging circuit. It won't harm your battery.
My advice, keep the Schumacher, it is way smarter and will charge your battery faster as it is designed for that. I know this makes no sense, but when you need to charge in cold weather, it will work faster. I have an SC1200A 12/8/2 and use it.
The hd24 should be ok for a weekend, unless you run a furnace fan. My TT came with a single grp24 on the tongue. I could fit a grp 27, but I replaced the grp24 with an AGM and keep it inside under the bed/dinette. I use the tongue to carry a generator.
HTH;
John
