jerryleejr's avatar
jerryleejr
Worth the effort?
I’ve stumbled across what I believe is a decent deal on a 3500 CC. The catch is its SRW. I’ve never done a conversion to DRW nor 19.5” wheels. However using OEM parts will increase payload 2K for this model year and put me more comfortably where I need to be at a significant savings over a new truck. Just making sure the initial savings is worth it and not cause headaches down the road...
JJ
  • There’s 2 ways to covert. Buy the Arrowcraft kit and use the existing axle, but it might not have much reserve capacity left. It’s nearly as easy to just swap in a dually axle.
    FWIW - I originally converted my can with the Arrowcraft kit. No issues with that kit, but my axle was a Dana 70 and was was still pushing a it 7,800# rating. One trip i spilt my diff carrier in half once when I jumped the van going a wee bit too fast, with a trailer in tow on a hitch extension. Then another trip I sheared the pinion gear, sending my driveline across the highway, when I did a 3rd to 1st WOT downshift with torque management turned off, when I went to pass a Honda Civic on a steep uphill while towing the travel trailer.
    So now I have a dually Dana 80 axle. If I break this one, I’ll try the Dana S110 next, since my rear axle weight does top 13,000 pounds at times
  • It sounds like a worthwhile upgrade, on a later model truck. The guy with the van in pic told me the cost of kit (I don't remember), and not a big deal to convert. I think cost was less than I expected, but you have likely checked on that.
    Jerry
  • C Schomer wrote:
    That sounds fun but I would check the axle weight capacity to be sure it’s worth continuing. Craig
    The conversion would include the upgraded axle....
    JJ
  • That sounds fun but I would check the axle weight capacity to be sure it’s worth continuing. Craig
  • MFL wrote:
    A bit more info would help. What 3500 truck, brand/year, and what do you plan to tow with it?
    Had a camp neighbor next to me with a converted 350 van, towing a little mini trailer.
    Jerry
    It’s a 4th Gen Ram 3500 CC and would be hauling 5-5500 in the bed and towing a small utility trailer. Most do the same with the 3500 DRW’s which why I’m looking at the conversion...
  • A bit more info would help. What 3500 truck, brand/year, and what do you plan to tow with it?
    Jerry
