Gear box ratios are torque multipliers and generally are about 10% difference
between ratios offered
Your 3.73's multiply the drive shaft torque by 3.73...4.3's will multiply and
provide about 15% more torque
So if the drive shaft has 100 ft/lbs of torque, the 3.73's will send approx
(there will be losses) 373 ft/lbs to the axles. 4.3's will send approx 430 ft/lbs
to the axles
MTWR's is very dependent on axle ratios...just check any brochure or specification
sheet from any OEM
Absolutism this is NOT, as the axle ratio is just one of the components of this...meaning
to just talk about a 3.73 vs 4.3 is out of context of the whole
system. There are many other factors. Diesel, big block, small block,
forced fed, cam profile, etc, etc
The tranny gear ratio(s) and the ICE's torque curve must also be factored in...as
would the tire OD...best to use their rev's per mile...that is more accurate
"Torque band" is the HP/Torque curve and choosing the tranny gear ratio
and axle ratio vs whatever you wish as your priority
If MPG is high on the 'have to have' list, then the lower numeric diff
ratio.
If towing is high on the 'have to have' list, then the higher numeric
diff ratio.
BUT...you can't have the best of both worlds...there will be compromises...
