spoon059
Jan 19, 2020Explorer III
Gald65 wrote:
Is anyone out there towing that type of weight with one of the newer F150’s with the 13000lb configuration? Are you happy with the handling? Should I stop being a tight a$$ and get a 3/4 ton truck?
TIA
A newer F150 with a 13,000 lbs GVWR is going to be on the more expensive side. If money is the issue, you can get a 3/4 ton for low to mid 30's.
What is the matter with your Denali that you aren't "happy" with it? Correct me if I'm wrong, but isn't the Denali on the more expensive side of GM trucks?
44,066 PostsLatest Activity: Mar 14, 2015
