Grit_dog
Jan 21, 2020Navigator III
ShinerBock wrote:Grit dog wrote:
^Sway = a little wiggle probably. Everyone's definition and sensitivity to the sensation of a trailer is differnet.
That and not all half tons are made the same. Unlike the progressive rate coils on the 2500's, the linear rate coils on the Ram 1500 are soft compared to the suspension setups of the other two. I have a friend that tows his 6k trailer with hos Ram 1500 Ecodiesel. He could not stand the squat and sway with the stock coils and installed after market progressive rate coils from TufTruck. Unloaded ride got a little harsher, but loaded ride was way more stable and almost zero squat with his trailer hooked up even without the WDH hooked up.
The good thing for him is since he mainly only tows the trailer twice a year down to the cost in spring and buck up in the fall, he can very easily swap out the coils back to stockers when he is not towing. It literally only takes him about 10 minutes to swap.
Ya, theres probably alot to be said for beefing up the rear suspension on the Ram 1500s. I like Rams and I wouldn't buy a newer 1500 if I was going to work the truck unless I planned on giving the suspension some help.
That said, the gentleman also said that he can live with it, meaning he likely understands sway and SWAY!
But then again, I consider it a decent tow if the trailer isn't trying to pass the truck!
For the OP, he either needs to gain more confidence in his rig, set it up better, understand how it reacts, or just over truck himself into a rock solid towing situation for peace of mind. Nothing wrong with that. I understand the luxury and virtues of having more truck than needed, but also understand that it's not always in the cards or necessary either.
