librty02
Jan 23, 2020Explorer
Gald65 wrote:
Back story-impulsively purchased a 2006 keystone 26tbl. Loaded weight about 7700 lbs. At that time towing with a 08 Sierra cc. Obviously not enough truck. Purchased a 11 Sierra Denali cc with the 6.2. It definitely does much better. It has plenty of motor but the handling leaves a little bit to be desired.
The question- eventually I plan on upgrading my trailer to something that has a loaded weight of around 8500 lbs. I know that I won’t be happy with the Denali. Is anyone out there towing that type of weight with one of the newer F150’s with the 13000lb configuration? Are you happy with the handling? Should I stop being a tight a$$ and get a 3/4 ton truck?
TIA
As you can see in my sig I have 2 F-150s that I tow my 7200lb GVWR trailer with and have now for well over 50000 miles with these 2 trucks and both have been absolutely amazing doing so in every way. I have been all up and down the east coast through the mountains of PA, WV, and NC over and over again. My 18 F-150 has the 13k configuration you are talking about. Many naysayers here that have never towed with the new aluminum body say that the new aluminum body does not tow as well as the previous generation did well let me tell you that is an extreme FALSE statement as my 18 with the aluminum body is more stable than my 11 is.
Before I could answer your question completely I must know....
-How often will you be towing this future new to you 8500lb GVWR trailer?
-What will be the total length of the new trailer? As this plays more of a rule in towing than the extra 800lbs of weight does?
-Would this new truck be your daily driver also?
-What would be total weight of passengers and gear in the truck while towing?
I will say if it were going to be your daily driver that you also use it as a tow vehicle say 3000 miles a year I would stick with the half ton and forget the 3/4 ton on one condition. I would go to Ford and order a F-150 with the 3.5 Ecoboost, Max tow package, and HEAVY DUTY PAYLOAD PACKAGE (HDPP)...that HDPP is key I would say for any half ton towing any travel trailer over 8K as you will need the added payload that package provides you. Without the payload package on avg a crew cab will have around 1700-1800lbs of available payload. With the HDPP you will be up around 2300-2400lbs of available payload.
Others will say well you can get a same equipped 3/4 ton for the same price as the F-150...that is complete BS as the incentives on the 150 are always a lot more than the 250 are. When I shopped the last 2 times for a truck the same equipment in both trucks same sticker price the 150 was 10k cheaper out the door in the end and if a daily driver that will net you better fuel economy also at around 33% better.
