Groover
Jan 23, 2020Explorer II
BenK wrote:
It's all opinion...
RGAWR is the main spec I look for in my decision for a truck and that is one of the Laws of Physics
Haven't looked it up in a couple of years or so, but half tons top out at around 4,800 lb RGAWR, that hasn't changed much for decades. Not enough truck for my main TV...edit2...4.8K is the top end rating...most half ton RGAWR's are in the 3,xxx lb range...bell curve has low 3K's to 4.8K as top dog. My preference is for 6K or more RGAWR
Yes, newer half ton's are rated to tow much more than before, but, IMHO there is more to it than MTWR...RGAWR is more important
The OEM'S designed everything around the RGAWR and rude quality is high on these buyers "have to have" list
Why more half ton owners discuss or have after market rear axle helper springs and higher class tires
Nothing wring with that. It's a personal choice thing...just understand that adding higher spring & tire capacity does NOT increase RGAWR...that is a Law of Physics
Sure, the OEM'S have design margins and note that by increasing spring rates e as t into those margins...
Edit1...seat belts
There was a time that they were not mandatory. Ditto other things like TPMS, safety glass, ABS, etc, etc, etc...
Until too many were maimed or killed. So they became OPTIONAL
Till folks continued to be maimed or killed...so DOT made them mandatory...to then make them either employed without human interaction...or madding buzzers that went off after you used them
If the government can show that a device will more than pay for itself through safety, not only for the purchaser but also the world at large, then it should be mandated. But mandates that do not help the world at large and/or personal freedom should be seriously questioned. Requiring the use of seat belts is one of those.
I am in favor of having seat belts in cars and I wear mine religiously but I don't believe that the government should have any say in whether or when I (or other occupants of the car) actually wear it. That is getting too invasive of personal freedom and I value freedom very highly. I don't want to live in a nanny state. We all know anyway that the best way to reduce deaths is to slow down some. If the police showed as much zeal in reigning in drivers that are a menace to society as they do for ticketing people not wearing seat belts a lot of wrecks could be avoided altogether. Those that do happen would be much less dangerous.
Some things that would not cost much or infringe on freedom would be requiring all cars to come with DRLs(daytime running lights), automatic headlights including high/low beam), automatic wipers and lights on when the wipers are on.
The bottom line for me is this, the government should protect me from you and you from me but not me from myself. We all have a right to freedom even if that means allowing for some stupid behavior.
