ShinerBock
Jan 24, 2020Explorer
blt2ski wrote:Lantley wrote:
blt2ski wrote:
"Buy what you think will work, at the end of the day,. You can only hope it meets your needs. Or as many do, you buy a known bigger power output truck, chassis etc than is truly needed, as many on here say you should do"
Trucks are way too expensive to buy a truck and hope it works!:S.
I don't believe everyone needs a dually. I do believe additional margin/capacity is a good thing.
Hoping it works is a worst case scenario, One must do enough homework
to know the truck will do the job.
Buying the right truck on the 2nd go around is always a costly mistake.
Hence why I do not trust tow specs from manufactures. Even the new everybody is supposed to meet tow specs, are too easy to meet in some ways. A min 12%grade pull in first gear! I can name multiple roads steeper than this that one would stall out on! Min speed of 40mph on a 5% freeway grade, 35moh if over 15000gvwr truck. Some on here would poop bricks going that slow. If I can't go up a 30% grade and start on a 30% grade I poop bricks.
Know what ratings mean, how they effect you, and reduce accordingly!
Narty
When it comes to speed, the 3.5L Ecoboost and 6.2L Ecotec provide more power than what the truck can handle. The opposite is true for the 3/4 ton gas engines. I am not sure about the new gas 7.3L, but so far it is looking to be the same way. We are also talking about a trailer the weighs just 8,500 lbs. Does one really need a 3/4 ton gasser that is slower, uses a lot more fuel, and is a lot harder to maneuver for just an 8,500 lb trailer. No doubt the 3/4 gaser would be more stable towing, but we are just talking about 8,500 lbs here.
