blt2ski
Jan 24, 2020Moderator
Huntindog wrote:A few local boat Ramps are that steep.I gotta know where these are....
Maybe we can all get together and watch people back their TTs into the lake...
This sounds like fun... I will bring a 100 QT cooler of beer to share with my RV net friends.:B
Renton Was, south end of lake Washington, shilshoal bay marina, Puget sound. Many folks with RVs tow and have boat trailers too! Its real nice to have a steep ramp, especially if your trailer has an extendable tongue, and a boat that needs to float off and on, because you can not use rollers and a winch.
Tow ratings do not just entail pulling RV trailers. Boats, equipment traikers, snow mobiles etc.
What or how you expect a tow rig to do, are your performance ratings or specs. If you don't have to dead start on steeper grades as I do, oh well. Different trailers require diffent power specs, even if the same weight. HP needs cab vary by 30% vs base setup ratings start at.
Ask folks that deliver trailers best mph. A non slide smooth walk 5w. Worst, aluminum sided TT. A heavier smooth sided TT same floor plan, nets better mph! Les HP needs
Garbage trucks spec sn 80%gradabiluty, that's 40degrees. Some 100%ir more is needed depending upon task.
My performance specs are harder to meet than Detroit engineer specs.
Marty
44,066 PostsLatest Activity: Mar 14, 2015
