blt2ski
Jan 25, 2020Moderator
Lantley wrote:GDS-3950BH wrote:Huntindog wrote:A few local boat Ramps are that steep.I gotta know where these are....
Maybe we can all get together and watch people back their TTs into the lake...
This sounds like fun... I will bring a 100 QT cooler of beer to share with my RV net friends.:B
This is a street where I grew up, it's a 28% grade. A 4WD truck can get hung up if you stop when its just wet if you have the wrong skins.
The big thing was, and probably still is, to run up it when it had about 6" of snow on it. You needed to have a manly set of em as the running start required was brutal when you hit the bottom of the slope. I made it once with an International Scout. I made it halfway once in a 68 Bronco, the sideways slide back down was interesting.
Are you suggesting trucks should be rated based on this criteria?
YES!!!!!
If not, you think you can go anywhere, you can't, blow up trannies every 30k as I have with one truck. You may find roads this steep for shirt trecks anywhere! Be it a forest service road, local city road, construction site. If one is buying a truck, not all of us use it for OTR work.
Look at how MDT/HDT trucks are speced. Local delivery, min pulling grade is 25%,ma x us over 100% 45 degrees depending on what it is. Can hold 58min on level, to excellent is 55 on a 3%freewsy grade.
OTR freeway speeds are upped to 60, gradability is lowered to 15 minimum. Excellent 28%,
How do you use your truck and where? I'm personally more local driving, with excursions on freeway. So yes, being able to pull this grade in RWD with a RWD or a 4x in RWD is very important to me! A big motor is not as needed, as lower gears in rear pumpkin, and LOW gears in trans are important. Then make it with a DOD or OD so one can go 60+ when and if needed.
Hopefully my thumb typing has words correct, blinken auto correct on phone is reasonably correct in what and why I like to spec my trucks as I do.
Msrty
44,066 PostsLatest Activity: Mar 14, 2015
