Gald65's avatar
Gald65
Would I ever be happy towing with a half ton truck
Back story-impulsively purchased a 2006 keystone 26tbl. Loaded weight about 7700 lbs. At that time towing with a 08 Sierra cc. Obviously not enough truck. Purchased a 11 Sierra Denali cc with the 6.2. It definitely does much better. It has plenty of motor but the handling leaves a little bit to be desired.
The question- eventually I plan on upgrading my trailer to something that has a loaded weight of around 8500 lbs. I know that I won’t be happy with the Denali. Is anyone out there towing that type of weight with one of the newer F150’s with the 13000lb configuration? Are you happy with the handling? Should I stop being a tight a$$ and get a 3/4 ton truck?
TIA
  • It depends on you and what you want vs what you are willing to live with. Most of my 20 years towing RV have been with duallys, so I am used to no drama towing.
    Last year we purchased a F150 max tow and a new smaller trailer. Its about 8,000 loaded. We did a 5000 mile trip last summer. It did wonderful but I have upgrades throughout the truck.
    I have always upgraded shocks on every truck to the Bilstein 5100 series. This truck I added 10 ply E tires and a ride control air bag system. I also use an old Hensley Arrow hitch. The only problem that I had was in high winds when the Hensley Arrow hitch and the factory f150 sway control began fighting each other. Once I disabled the F150 sway control we had zero problems. My wife is very comfortable towing this combo and she believes it is one of the best combo's we have had.
    Good luck, research you capacities and limits, and if you go decide on the HD platform, skip 3/4 and go to full ton SRW. No real penalties for the payload increase. I love the F150, but know that once the kids are gone, a truck camper is in my future, and I will go back to HD's again.
  • I am not sure how the new lighter trucks are, but I towed 9,500 lbs several times a year with my old F150HD Ecoboost. Even towed on a few long trips through the Rockies. I loved that truck(especially tuned) and the only reason why I stepped up to a Ram 2500 CTD is because I got a trailer that is 14k fully loaded which is definitely the max I will ever want to go on trailer sizing.
    TIA
    You are overdue.
