Me_Again
Mar 09, 2014Explorer III
Hannibal wrote:Me Again wrote:Hannibal wrote:
4.88 is for 1st gear launch power. Unless you're launching heavy up steep grades or carrying a heavy box around town all day, it's highly unnecessary. Personally, I'd prefer a 3.55 ratio for a 12k lb 5th wheel. 1750rpm at 65mph with the diesel is about right. Downshift when needed and get better mileage on the flats and running empty.
What does this have to do with a Ford F450? You are talking apples and oranges.
Chris
Has to do with the OP's OP. Using an F450 to tow a 12~lb GVWR 5th wheel doesn't need a 4.88 ratio gear set. No different than towing it with an F350 or even an F250 as far as gear ratios go. Why would that be apples and oranges?
A F450 with tall gears will be a dog. They put low gears in them for a reason. Resell would be in the toilet. So you spend money to screw it up and then loose again to dump it. BTW did you happen to read that OP decided to leave it as is now? Chris
44,064 PostsLatest Activity: Apr 12, 2026
