Me_Again
Mar 09, 2014Explorer III
Hannibal wrote:Me Again wrote:
A F450 with tall gears will be a dog. They put low gears in them for a reason. Resell would be in the toilet. So you spend money to screw it up and then loose again to dump it. BTW did you happen to read that OP decided to leave it as is now? Chris
Why would an F450 with 3.55 gear ratio be a dog? A 3.55 ratio in direct drive would be more gear reduction than the 4.88 in O/D. By your assertion, an F350 with 3.31 gears would really be a dog? Unless you're towing max capacity, there's no need to have it howl like a banshee all the time towing or not. That the OP decided to leave as is for now doesn't change the fact that your assertion is false.
What ever. If you had one and wanted to screw up it's towing ability, well it's yours to screw up. OP seems to have seen a light that you have not.
44,064 PostsLatest Activity: Apr 12, 2026
