mkirsch's avatar
mkirsch
Nomad II
Jul 09, 2013
Would more room make loading easier or harder?
Even with extended dually swing-out brackets, I only have about 1.5" of clearance between the fenders of my 2002 Chevy 3500 DRW and the jack posts on my Palomino B1500 TC.
The outer duals just rub the jack feet as I back through. There is no room for error.
The upside to this is that I can't back in crooked. If I squeak between the jack feet, the camper lands perfectly on the truck every time.
The downside to this is it is VERY stressful. If I'm off by even a fraction I could knock the camper off its jacks if I'm not paying attention. Not to mention the excessive body damage.
I am considering welding another 2" extension on each swing-out bracket to gain myself some more clearance on the outside.
Will the added clearance outside help with loading and unloading?
  • I've never measured exact clearance between swing out posts and dually fenders on my 2000 Ford F350 and Arctic Fox rig. I know it's not alot of room...I think the basement is even tighter on the wheel well molding on the inside of the truck bed. You'll still need to be closely aligned not to hit those even if you add the bracket extension. Does that make sense?
    However if the outer duallys rub the jack feet, I would add the welded extension you're talking about. Send some pics once complete!
