~DJ~ wrote:
smkettner wrote:
What does the cabinet space measure without that battery box?
Sure looks like both would drop right in.
Maybe, if I removed the converter but I don't know where I would move it to.
I cant see what might preclude moving- wires not long enough or if it would be enough space or how much additional room you need, but theres a step in cabinet under stove, 3" rearward? You would need to swap around some of premounted stuff but simply cut the false wall and move it out. Just 1x1s and 1/8" paneling. Hardest part I see is reusing paneling and working with existing holes.
Cut wall reassemble with a piece of 1x4 and a few pieces of 1x1 or 1x2.Cut full height 1x4, attach 1x2 to its edge, reattach the face of moved panel to edge of 1x4 with the 1x2 behind original panel, reattach it.
But dont know if the 3" or so would give you room for another box. Pics may be deceiving, as other have noted, just looks like its close.
Only reason I could see not moving the wall (short of none of the wires would reach) is the stove right there. You might have to stand like Captain Morgan while flipping your hotcakes in the morning. Though would be less protrusive than an additional box?
Otherwise, except for the stove consideration, Id bump out- If it could be worked around, move some more stuff build a step. Likely would need new paneling or ply.
Then again Im looking at it from a few hundred miles away-probably have some horizon haze interfering with the view-looks simple from here, 'cause Im not seeing the details...
