~DJ~ wrote:
Holy Cow AnEv942!!!! That is very impressive!!!
I am definitely going to look into modding the cabinet.
I have another question. If two 6 volt batteries rated at 220 AH stay the same when doubled to 12 volt what happens when they are quadrupled?
Will 2 130 AH 12 volts double to 260? If so, it sounds like 2 12 volts would be better than 2 6 volts. :h
And as was brought up earlier, if 1 of the 6 volts fail I'm dead in the water but not so with twin 12 volts.
Ha...ah 18 volts @220?
What I would do IF i had room minus the weight is run 4 6's- But thats why I went with 2 12s. There are many pluses running 6s but only 2 ? I dunno, my leds might run on just one.
Ya your cabinet looks really simple to change-but get your tape out and make sure itll give you enough room.
