RVcircus
Oct 07, 2016Explorer II
CopilotCompanion wrote:
Stupid Question Number 849: How do you look inside the underbelly? Don't you have to remove the whole thing to see inside? Or, are there access hatches/ports?
It's likely sealed. You may be able to find an opening or remove a few screws. It's likely either a tarp like fabric stapled or screwed coroplast.
#850: Will I learn what a pressure test is if I plug it into the Search field? Does this check the integrity of the slide's hydraulics? Or does it somehow measure the integrity of the seal? Is this a test a mobile tech can conduct and how many $$$ are we talking about?
Here's a link to locations that do Seal Tech pressure tests: http://www.sealtechleaktesting.com/. There are also DIY methods using a blower to create pressure.
44,056 PostsLatest Activity: May 04, 2014
