TxGearhead's avatar
TxGearhead
Explorer II
Jan 10, 2019
Would you..
...carry 4 or 5 gallons of gasoline in a Berg long run fuel tank (boat gas tank) in the basement of a TC? In a plastic tub? With an old style closable vent on the tank cap?
I haven't done it yet, but I'm tempted if it is required.
Unfortunately I have a A/C on my Bigfoot that requires 2 Honda 2000 gens to run. Why Bigfoot, why?
I don't mind giving away $10 worth of gas rather than driving home 800 miles with the gas in the basement.
Your opinions welcomed....
Yeah I worked in a refinery for 40 years....
  • Change out the ac to one that only requires one Honda and sell the extra ac and extra Honda on Craig's List. Problem solved.
  • I’ve done it with a trailer-hitch-mounted carrying rack on the back, behind the truck and below the camper. If your Honda’s don’t fit in your generator compartment, put the gas cans there.
  • Years ago I bought gas cans in Canada. Even they cost like $7 a piece, they are much stronger than what you can buy in US and have gargling nozzle instead of spring loaded valves, where spring flies away on 2nd use.
    I do carry 2 of those in empty generator compartment.
    For short trip I would not hesitate to put it behind driver seat, but they do smell a bit.
    Boat tanks are not any stronger and than they are not design for pouring fuel out.
    Than you can always buy military style metal gas cans.
  • I carry three 2.5 gallon plastic fuel cans in the vented compartment originally designed for an onboad genset. 8 years no issues no fumes to fuel my Honda 2000
  • Just a idea,could you mount a fuel tank between the frame of the truck. Or maybe some kind of a bracket that would hold a small fuel can. I would worry about gas fumes in the basement of my TC.
  • Sounds like a bomb, so no I wouldn’t put several gallons of gasoline under my TC.
