bsaws6's avatar
bsaws6
Would You Tow
I have a 2013 Tundra DC 4x4 5.7. I am looking at both the 2014 Jayco Jay Flight 28bhbe or the 2014 StarCraft Autumn Ridge 289bhs. Would my TV handle either of these or should I look smaller/lighter? I am new to forum so hope this is right section. Thanks
  • We had a similar situation to It's Me with our last TT - slightly over on the truck's payload but within axle ratings (barely). The truck did ok with it, but I would not have wanted anything larger. Our TT's GVWR was 7600 lbs. Just traded it in for a smaller, lighter one and I think we - and the truck - will all be happier.
  • It looks like you are looking at a gross weight of roughly 9300lbs on the trailer. The issue is going to be payload. Get a good weight distribution hitch and possibly bags or helper springs.
    I tow a 8500lb TT with my 2012 Tundra CrewMax. I am over payload by almost 300 lbs. and it pulls fine. But I load everything in the trailer and keep bed empty because of the tongue weight. I am within all axle ratings. You need to decide if you are comfortable over payload rating or not. It will definitely tow it though, should you, up to you.
  • 45Ricochet wrote:
    fla-gypsy wrote:
    We will need more information. We need the payload rating of your truck and the UVW/GVWR of each TT along with the dry hitch weight of both.
    I agree but my first guess is yes. At least your not asking about a 40' toy hauler :B
    X2. Should be good but if can supply trucks payload rating and the TT GVWR we can give a much more direct answer
    Welcome to the Forum!
  • We will need more information. We need the payload rating of your truck and the UVW/GVWR of each TT along with the dry hitch weight of both.
