420RVfun's avatar
420RVfun
Wow! I'm learning a lot.
So, I'm pretty much in over my head. But, I will continue. Way more water damage than I could have imagined. I'm replacing supports and have had to lift the rear end because it sagged due to the rotten wood. Lots of staples coming out, thinking of using metal tape on inside to help reinforce where they have been removed(aka-fallen out). Most of the floor is getting replaced. I'll try to get some pictures up.
I read about vapor barriers. Thinking I should do this, lots of little holes in the old floor membrane. Can I put plastic on the rubber floor membrane then add Floor joists and foam board insulation or should plastic go on top of floor joists? Does this make sense?
And another question? I believe that there is mold on some wood that is still strong. Do I just spray with bleach water and that will kill it, or should I do more extensive cleaning. I really want to keep some of these boards because a lot has come out already.
BTW, I am handy but not professional tradesman.
  • So I thought I'd found info on how to post pictures, but can't find it again. Any suggestions on the easiest way to share pictures
  • B-n-B's avatar
    B-n-B
    Explorer III
    How about just make this the official thread? Just move your pics to this thread and update in here from now on. Might be easiest.
  • B-n-B's avatar
    B-n-B
    Explorer III
    Sounds like your moving right along. I have seen "mold killer" sold in big box stores, but it's probably no better than bleach I bet.
    I noticed you have a couple threads open on this rebuild effort. To get the most help, I'd suggest sticking to one thread to update your progress, gather information and ask questions. It would make it easier to follow your progress and allow the peeps on the forum with the expertise your looking for to lend a hand without duplication of effort. Just friendly advice and something I noticed other members do in order to consolidate their rebuild efforts.
