tkoden wrote:
Just wanted to post an update. I used 4 automotive jack stands (its all I had and wanted to test before I bought other ones) under my travel trailer the last time I set it up, following Larry's suggestions. Since I did not have an electric tongue jack I used a carjack to raise and lower the tongue. The trailer is solid as a rock and I will continue to setup my trailer like this, I highly recommend it. Thank you Larry!!
My experiment has been less successful. I got two of those Al jacks, raised the rear about 1" about 18" behind rear wheel and dropped the frame onto them. Had to put them up on blocks to reach the frame without too much of the screw extension. Used the regular stab jacks and tongue jack up front.
If I then stand in the centre of the trailer and shift my weight (190#) front-back, left-right, the trailer still shifts. Not rock solid. They are just as good as the stab jacks that came with the trailer though, and a lot less fragile.
Thing is, these jacks are not completely rigid, loosely threaded, and where they press against the frame is also a rocking point, back/forth, side-to-side. They seem to need stabilizers like everything else.
I'm now thinking of going to heavy duty scissors jacks with the JT Strongarm stabilizers
JT Strongarm
