I have a cab over camper on my crew cab F350. When I have it on the truck, I loose XM reception. Is there an extended antenna that you could install to connect to a ford radio?
I picked one up at Best Buy. Its a magnetic pod that I secure to the front of the hood when the TC is on. When not in use I attach it under the hood and out of the way. Only use it when the TC is loaded. Otherwise Im back to the factory antenna.
