clancy47's avatar
clancy47
XM Radio
I have a cab over camper on my crew cab F350. When I have it on the truck, I loose XM reception. Is there an extended antenna that you could install to connect to a ford radio?
  • When we drive out west from PA I put my magnetic antenna on the driver's side of the hood, when driving back east I move it to the passenger side. Seems to help.
  • I'm looking for one too, but not sure where to look for them.
    Sirius only has some reconditioned one, probably the best value, but don't want to take the chance and Amazon has several but not sure which ones are the best.
    I went to Car Toys to see what they had, just a small 1" square one, didn't look like the other larger pods I've seen, so discounted it. Also, apparently it takes a special "FAKRA Connection"?? but the amazon doesn't have it.
    Factory installed radio/siriusXM, got it with the truck new.
    Looking at this one:
    (Arrrrggghhh... switching to Advance post... PITA)
    So names? links?
    Would be helpful..
    Here's the one I usually see, from Crutchfelds
    (Update)
    enh???
    I just ordered the square one with adapter just in case...
    thanks...
  • cubbear wrote:
    on my 2015 F350 XM plug down by steering column I bought extra antenna & plugin from ford and mounted in front of windshield on drivers side works great. there is article somewhere that shows exactly what to do
    Did this also, permanently moved connection to new antenna on cowl in front of windshield. Works great with camper on or off the truck.
