ktmrfs
Dec 26, 2016Explorer III
mtofell1 wrote:
I skimmed the responses so I apologize if this has been covered - I'd try to isolate if it's a problem with your equipment or with the signal. Basically, does it go out in the same spots on your drive each day? Mine has a couple dead spots that fade out everyday in exactly the same places. If that's the case there isn't much you can really do.
x2. and check the headliner up near where the antenna is. if there is any evidence of moisture you likely have a leaking seal around the antenna, which then can cause corrosion on the XM, onstar, GPS and cell connections.
44,066 PostsLatest Activity: Jul 25, 2018
